Coolant Leak
Coolant Leak
Im at a loss here, this morning I drove my Porsche into work, when I got there, i was leaking antifreeze/coolant at the reservoir area. The car wasnt running hot at all. About 8 hours later, I drove home, after adding some coolant. Well, no problems on the way home, no overheating issues what so ever. I pulled into the driveway and notice a trail of fluid down the street and into my driveway. Same problem, coolant leak quite a bit I might add under the reservoir area....Help...I dont know whats up.
Most shops can do a very inexpensive and fast "pressure test" of your system to determine where the leak is located. Often it's just a loose or cracked hose and an easy fix.
You can do these tests at home if you are even remotely inclined.
In the meantime look for obvious loose hose clamps/split hoses (squeeze each hose to see if coolant gushes out from a split), failed radiator cap, etc. You'll probably get lucky and not have a serious leak (e.g. blown headgasket, failed water pump, burst heater core) but because those possibilities exist you'll want to check the car out ASAP.
When she cools off, take a look at how low your coolant level has dropped in your reservoir.
Inventor
I had the same symptoms recently. It turned out to be the coolant pressure sensor, which is about a hand's width forward of the reservoir, by the washer fill tube. It would only leak when the engine was at full temp. The sensor splits down the middle. You may see a white residue on it if it has been leaking.
I replaced it with a new section of hose, and a 8mm (5/16") connector.
Other possible problems: reservoirs can crack, and the caps can leak.
I also had this problem, and it turned out to be a crack in the plastic reservoir. Just replaced it, now I have a small crack in one of the plastic side tanks
Figures, nothing is cheap with this car I checked around today under some more light, there was no further leaks. Im gonna take her to the mechanic to have a more detailed inspection. I felt around the reservoir and didnt see any leaks either. Im not quite sure if what I saw was the sensor, but it looked ok, so will see. I lost about an inch of coolant in the reservoir but overall still a lot left inside. Hopefully its pretty simple fix. I will update, thanks!
