928 Forum 1978-1995
Sponsored by: 928 Specialists
Who has the best cooling fan kit?
Old 07-20-2009, 01:52 PM
Shane
Sharkaholic
Shane's Avatar
That is exactly how Hacker wired up the fans on my SuperShark.
Originally Posted by PorKen
Great tip! I was wondering how to wire my dual 11" SPAL in sequence.
I did a little searching, and found that the 3 terminal fan switches are used on many VW, Audi, SAAB, etc. Note the middle two appear to have different on/off ranges. The middle terminal is the common.
191959481C | 95-81/102-91c
321959481 | 85-80/93-88c
251959481K | 85-74/93-82c
25195948175 | 75-70/82-77c
Old 07-20-2009, 02:09 PM
PorKen
Inventor
PorKen's Avatar
I think I'll get this one.
I can't think of what the greater hysteresis (longer on time) would be good for, except that the second fan would stay on until below the threshold of the first?
Old 07-20-2009, 02:19 PM
David L. Lutz
David L. Lutz's Avatar
Originally Posted by GlennD
Just wondering if the switches in the temperature sender are capable of dealing with the current required for the fans.
I would wire the switch contacts to a set of relays (one relay per switch) and use the relay contacts to drive the electric fans. The relays can be purchased with the correct current ratings (e.g. 20 amps per contact set). The relays could be simple (e.g. SPST) 12 volt relays.
If you decide to use relays, I would also suggest putting a snubber diode across the coil (IN4001 or similar) to prevent the back EMF from getting into the electrics of the car.
Back EMF (electromotive force) = induced voltage when power is removed from an inductor (the relay coil). This induced voltage is equal to
V = L dI/dt or the inductance of the coil times the change in current over the change in time (time would be short since the relay coil is being driven from one to off in the time it takes the temperature switch to open).
Cheers
Glen,
I was thinking of using this relay connecting the sender to the grey wire (ground) which activates the relay.
http://www.spalusa.com/store/main.as...etail&item=FRH
Would I still need the diode? If so could you be a little more specific as to the placement of it. Haven't exactly done that before.
Old 07-20-2009, 02:20 PM
David L. Lutz
Here is the spec. on the relay.
http://www.spalusa.com/pdf/FRH_SPEC.PDF#view=FitH
Old 07-20-2009, 03:18 PM
GlennD
GlennD's Avatar
Dave,
Looking at the last page of the PDF specs, you see a device connected across the coil (terminals 85 and 86). This should be the snubber diode. Unfortunately, the manufacturer does not explicitly state what that device is (but if I was to guess ....). May be worthwhile dropping an email to the manufacturer or perhaps your supplier can confirm.
Google 'snubber diode' for an explanation of what the purpose is and how to connect.
whites.sdsmt.edu/classes/ee322/class_notes/322Lecture4.pdf
The diode would be connected opposite of what you think. A diode conducts current in one direction (follow the arrow as shown on the diode). So, positive flows from ------->|---------
Connecting the diode opposite (so the arrow is connected to the ground) prevents the diode from normally conducting. It then only conducts (e.g.: acts as a short) when the coils is de-energized.
This information is for those that wish to wire up their own relay and the relay does not come with a snubber. This saves those pesky induced voltage spikes into the car's electrical system.
Regards
Glenn
Old 07-20-2009, 03:19 PM
GlennD
GlennD's Avatar
Let me know if you want more details or a drawing. It would be my pleasure
Glenn
Old 07-20-2009, 03:36 PM
danglerb
danglerb's Avatar
Start current is about three times the run current, and with all the nasty back emf issues of inductive motors. Some after market fans advertise using the start current, so maybe some of them might work directly with the switch, or for awhile, but relay that can easily be replaced is the way to go.
If you use a relay rated at least twice the continuous running current, it will usually handle the startup current fine.
One advantage of a dual, or two speed fan, is the ability to start with one fan or on the low speed.
I could have this all wrong, but when I used IR and probe to measure radiator temperatures the return side tank was around 145 F, 85C is 185F, and 80C is 176F, that doesn't sound like it will work to me.
Old 07-20-2009, 05:40 PM
sharknoob
sharknoob's Avatar
Any reason why you wouldn't want to use a variable speed controller it ramps up the start up to limit in rush and will run fan for 30 secs after car is off
Old 07-20-2009, 06:19 PM
David L. Lutz
Actually I am very much considering this one from Spal.
http://www.spalusa.com/store/main.as...tem=FAN-PWM-V3
But considering the expenses I have just had, I was trying to go a different route using just the relays and sendor.
Old 07-20-2009, 07:07 PM
danglerb
danglerb's Avatar
I think a variable controller is the "best" way to go, but the Spal will fry with any of the fans I want to use (max fuse is 30 amp). I have a DC Controls PWM on my 83, and while they seem to work perfectly for most "normal" applications I am still fussing with mine, and the vendor has no interest in sorting out new applications.
Old 07-20-2009, 07:16 PM
Drewster67
Drewster67's Avatar
Default Summit Racing and they are on sale.
http://www.summitracing.com/search/B.../?autoview=SKU
Old 07-20-2009, 07:59 PM
danglerb
danglerb's Avatar
I wouldn't trust those fans or their ratings.
BeCool is a fairly respected brand.
Three things a big factors in what the fan will flow, diameter, blade coverage, and amps. The first two are related to efficiency, and the last is the power.
Old 07-20-2009, 08:26 PM
David L. Lutz
I have very limited space issue on the '87. The 16" fan is mounting in front of the A/C condensor and in total I have less than 4" of clearence.
To date I have tried two Zirgo Fans and on one the shaft striped apart from the blade (this one being their Ultra HP model) and the other was a puller design that was not that high rated to begin with.
I have moved on to Spal hoping for better results, but am always open for new and better options.
The Spal (pt. # 30102047) is a pusher design and seems to move more air than the Ultra Zirgo. (spec. reads 20amps at full draw) I have only had the Spal installed for a couple of weeks now and its doing a fairly good job of keeping temps. down in very hot weather.
Old 07-21-2009, 01:35 AM
H2
H2's Avatar
I was disappointed w/the Zirgo fan I bought. It certainly doesn't push the air the advertisement claimed.
H2
Old 07-21-2009, 01:43 AM
UncleMaz
UncleMaz's Avatar
FWIW, I used a Flex-a-Lite brand fan on my jeep for years with 100% reliability going everywhere in every condition as a viscous fan replacement.
Quick Reply: Who has the best cooling fan kit?
