928 Forum 1978-1995
Sponsored by: 928 Specialists
need distributor for '82 Euro
Old 07-13-2009, 05:18 PM
Sab
Sab's Avatar
Default need distributor for '82 Euro
I am unable to resolve a timing problem on my '82 Euro.
Could someone lend me a distributor, so I can swap and eliminate that as the cause?
The car will not advance enough during the RPM curve... I am suspecting the centrifugal advance to be inop.
How much are those things anyway?
Old 07-13-2009, 05:27 PM
Lizard928
Lizard928's Avatar
They can be disassembled and the springs/weights changed to modify the curve.
Old 07-13-2009, 05:36 PM
Sab
Sab's Avatar
Thanks Colin,
I had someone supposedly rebuild it with no change to problem.
I would like to find a good one to compare and then decide if I will buy one or attempt the rebuild myself.
Is the effect of the centrifugal change big?
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Sab it might help if you posted the distributor number.
Old 07-13-2009, 05:38 PM
Sab
Sab's Avatar
thanks Mark, where do I find the number?
Old 07-13-2009, 05:40 PM
Mark Anderson
The Parts Whisperer
It's stamped on the case just below the cap.
Old 07-13-2009, 06:13 PM
Sab
Sab's Avatar
Old 07-13-2009, 06:14 PM
Sab
Sab's Avatar
it's hard to make out the number without pulling the dizzy out, but I think that's it.
Old 07-13-2009, 06:24 PM
Mark Anderson
The Parts Whisperer
0237 404 013
If that's it than it's one I've never seen.
Old 07-13-2009, 06:28 PM
Lizard928
Lizard928's Avatar
I would find a hotrod shop, and show them the curve you want.
They should be able to put any type of an advance curve on it you want.
Old 07-13-2009, 06:41 PM
Sab
Sab's Avatar
I think I found it... the number I gave you must be the Bosch part num. Here the Porsche number...: 928 606 033 00
Ignition Distributor
Type/Model
928 S
928 606 033 00 or 928 602 033 00
Bosch-No. 0 237 404 013
Version
Remarks
Centrifugal and vacuum advance and retard mechanism
Distributor rotor with speed limiter at 6500 rpm+l50 rpm
Old 07-13-2009, 06:42 PM
Sab
Sab's Avatar
Right now I would be happy if it does what it is supposed to. Something is not working and I can't figure out why...
Old 07-13-2009, 06:48 PM
danglerb
danglerb's Avatar
Do you have the vacuum hooked up to the correct port on the throttle body?
Have you checked the timing with a timing light?
Verified the vacuum operation with a MityVac?
Old 07-13-2009, 07:06 PM
Sab
Sab's Avatar
yes, checked all and it all seems fine. But when setting the timing as per workshop manual at 3k RPM, timing is way too retarded at 5500 RPM and therefore car has no power....
Old 07-13-2009, 08:52 PM
GRTWHT
GRTWHT's Avatar
If the engine isn't pinging, move the timing up.
I run 33 degrees advance @ 3000RPM (vac disconnected) you should see around 8 degrees advance at idle at this stage. Plug the vac retard line in and away you go.
I personally think the vac retard line holds the engines 'get up and go' back a little but it doesn't ping now. If you run no vac set the timing to 30 degrees (factory is 28 for my engine).
If you have mechanical problems with the dizzy then that's different, you'll have to get that fixed.
Glenn
'81 928 4.5L M28.10
AU
Quick Reply: need distributor for '82 Euro
