928 Forum 1978-1995
Sponsored by: 928 Specialists
Coolant Test
Old Jul 10, 2009 | 02:17 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Default Coolant Test
It's about time for another long, contentious coolant thread...
From a DIY automotive web site:
"Automotive coolant contains many additives. There are anti-foaming agents, lubricants, seal conditioners, corrosion inhibitors, and anti-electrolysis agents. As coolant ages, these additives wear out. Each of these additives prevents damage to critical engine parts. However, the one you want to test most often is the anti-electrolysis agent. Once that agent is exhausted, the dissimilar metals in the cooling system begin swapping electrons, causing significant and costly damage. Early heater core failure, for example, is most often caused by electrolysis. As you know, replacing a heater core in most late model cars involves removing the entire dash, evacuating the A/C system and the complete disassembly of the heater box and ductwork. That’s every bit of a $1,000 repair. You can prevent it by regular coolant changes.
Want to test for electrolysis in your coolant? Here’s the simple test: Using a digital multimeter, set it to read 12 volts DC. Attach one of the test leads to the negative battery terminal and submerse the other end into the coolant. Rev the engine to 2,000 RPM and reads the voltage on the meter. Any reading over .3-.4 volts indicates that the coolant is conducting too much electricity. Either the coolant needs replacing or you have a grounding problem in the vehicle. If the coolant is fresh, check for poor ground connections between the engine and the firewall and the engine and the negative battery terminal. ©, Rick Muscoplat "
So, what color coolant is best?
Old Jul 10, 2009 | 02:44 PM
Sailmed's Avatar
Sailmed
From: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
I'm guessing milky grey isn't a good color.
Old Jul 10, 2009 | 02:52 PM
danglerb's Avatar
danglerb
Why not just measure the resistance?
Back when I was doing a lot of 928 shopping I bought a bottle of coolant PH test strips from NAPA, but found most of the cars I looked at had recently changed coolant and/or oil.
Old Jul 10, 2009 | 03:10 PM
Sailmed's Avatar
Sailmed
On boats, we do measure for possible electrolysis using resistance - we immerse a silver dime in the water next to the boat, and check to ground. I can't see why it wouldn't work with the coolant. Good idea.
Old Jul 11, 2009 | 03:54 PM
911tracker85's Avatar
911tracker85
OK, dumb question for this audience.
I bought an 84 928S US spec last year. the PO had the TB/WP/thermostat/hoses, etc replaced. I am about to replace the elec fan temp switch and the another hose. the workorder did not specify but I called the garage that had done the work. the guy said they used Texaco green, since that is what is called for.
what are good options to get that would be compatible with this? I have read other coolant threads but they confuse me on this point. as you can see by my avatar, a 20 yr air cool guy.
Old Sep 22, 2014 | 02:03 PM
SMTCapeCod's Avatar
SMTCapeCod
Adding ref to the archana
http://www.network54.com/Forum/21142...ine+components
Old Sep 23, 2014 | 01:16 AM
SteveG's Avatar
SteveG
HTML Code:
Would that include any one of the many electrical gremlins that are associated with a batt drain? And if so, wouldn't 98% of our cars fail this test?
I think Wally's last question sort of pokes fun at this, but it does sound like it might have some merit.
Would it work with a batt maintainer hooked up?
