Powered by Porken!
Powered by Porken!
As a member of the secret S3 society I have been able to obtain parts from Porken for my car, in fact I have basically bought everything he sells. There has been a few threads with people really happy about his EZF'r chip for the S3. He came out with his long awaited fuel chip for the LH pretty recently. I uses either an AFPR or the S4 FPR, I chose the S4 FPR, and used 55psi which make injector load closer to 85% at WOT rather than 100% and more fuel to power the mid range torque.
I installed them last night and I am very pleased. Car responds, drives, and idles excellent.
All ebay chip users should resell them BACK on ebay and pick up a set of Porken's chips now that they are both out. I also hoped on the site to look at something and it looks like he is also making a fuel chip for the stock FPR, so for those not wanting to change the FPR then that should be done 'soon'
Thanks Ken!
Thanks Ken!
Anyway, it is nice to not only see someone fine tune the chips, but also fix the terribly 'broken' fuel chips we were using.
Inventor
Hmmm...if I were just a touch more narcissistic, that would make a nice window sticker.
For a couple of years I've been thinking about having a 32V sticker (~20mm tall) made. I'd put it on the lower right of the hatch, just below the spoiler, to warn that this S3 is not your father's OB.
Inventor
Someday, I want to try making a Kamm back for my '85. I guess I could put POR KEN on there.
Craic Head
I'm no Porken, but I did stay at a Holiday Inn last night. I'm going to say:
1. Crossovers with high-flow cats
2. Porken EZF'r/LH2.2r/55 chips with '87 S4 FPR (after replacing your fuel lines with a kit from Roger at 928sRus)
3. Drive it like you stole it!
Additionally, there are some gains to be had by going with a true dual exhaust all the way back, since the '85 has a 2-into-1-into-2 setup and the body isn't shaped right to just bolt on an '86.5 dual exhaust.
