Kinesis 3 Piece Racing Wheels
This is a great deal on the Kinesis. I have these on my GTS bought from Mark A years ago. I have 315's on the back and 275's up front. You won't be disappointed. Joe
Wow, thanks for the positive support everyone!
A lot of people are asking about offset. I can measure backspacing, but how do I measure the offset?
Owns the Streets
Needs Camber
Needs Camber
Offset is the hub face to centerline of wheel.
Say for the 10" wheel. 5" from inside hub face is the center.
Then measure at that 5" mark to the hub contact surface.
If the contact surface is outside of the centerline, then it's as negative offset.
Depending on the shipping cost it works out to be close to 90% of your asking price...if merely receiving an offer like that can insult you then you have too much pride. Or is it because I tried to use the force on such a righteous Jedi as yourself? Anyway, at least you got a couple of bumps out of my boorish behavior...
If the wheels are still unsold when I sneak a few hundred more into my Shark account I'll gladly pay the full price but I doubt they will go unsold much longer.
Those can't be correct. Are you sure you measured properly? Measure the backspace: put the wheel on the ground face down and put a straight edge across the back. Stand a ruler straight up from where the wheel contacts the hub and measure the distance from there to the straight edge. This will give you backspacing. You can then convert this into offset.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
Archive Gatekeeper
so:
wdith in mm /2 backspacing Offset
Front 8.5 215.9 107.95 185 77.05
Rear 10 254 127 195 68
EDIT: How does one post a frickin' excel spreadsheet without having to make a jpg out of it?
