Weird dying/non-start condition on a '89 euro GT
#31
Also, the last time we checked, it was spark issue, not fuel delivery.
#32
Team Owner
what was the last thing that was fixed prior to this happening, think carefully
#33
And since the issue is very intermittent (It could run for a week w/o any issues and on the 8th day it won't even start), it wasn't noticed initially.
Behavior isn't always the same either: it can lose power and die within 10 secs, or just shut down instantly. It's just a perfect example of 928 electrical gremlin.
#34
My '89 was doing some very similar crap. It turns out that after replacing/refurbishing/repairing a lot of the same stuff as you have done that it was the main engine ground. It was there and appeared fine, but I took it off and checked continuity which was fine. Took me 5 minutes. Cleaned the ends of the strap and the mounted bolt holes and reinstalled it and it has never quit since.
My impression is that it would run when it found a ground. The rest of the time it drove the computers crazy looking for a ground and would not run at all while they were searching everywhere for a ground.
YMMV
YMMV
#35
Is possible that the wires at the 14 pin connector are corroded? I found the #1 wire was completely rotted so I used some care and cut open the wire harness to where the insulation looked ok. Also the same is attached to the starter solenoid and was missing insulation there so I added more heatshrink there....voila it cranks right up.
My writeup on RW: http://reutterwerk.com/forums/showpo...4&postcount=36
EDIT: Local guys said you can also try to (*very carefully*) touch the #1 wire post to the hot post. Make sure engine is in neutral/Park as appropriate!! This bypasses the ignition switch.
#36
Some wires indeed were corroded, but we checked all harness from there and cleaned where it was bad.
Also, apologies for being unclear, the starter does engage.
Gonna check/clean main engine ground next, I guess. Should've done this earlier.
Thanks for all the input!
#37
Team Owner
also clean the 2 fuel injector grounds where they attach to under the rear throttle cable wheel at the back of the engine. ( remove the air cleaner)
There you will find the ground wires
#38
Supposedly we finally managed to figure this out.
Looks like it was the factory alarm system failing in a weird way! Will report later after replacing its brain.
EDIT: It was the faulty relay part nr. 928.637.16.000. Can be accessed by removing your stereo head unit.
