928 Forum 1978-1995
Sponsored by: 928 Specialists
OB: Pod Gauge and Warning Light Question
Old 06-25-2009, 05:35 PM
checkmate1996
checkmate1996's Avatar
Default OB: Pod Gauge and Warning Light Question
What electronic component or situation trips off the pod gauge warning lights when the igntion is turned to on?
Thanks for any help...
Old 06-25-2009, 06:50 PM
The Sharkologist
The Sharkologist's Avatar
Might be the Central Warning (indicator, whatever you want to call it) Computer that's located under the footrest on the d/s to the left of your pedals. Which lights are you seeing? It could be a bad sensor somewhere... That's just my stab at it, maybe someone else can confirm. Good luck with it, keep us posted.
-TS
Old 06-26-2009, 12:42 PM
checkmate1996
Well none of my lights come on, but I know they work. I've checked all the basics, I was wondering if it had to do more with the seat belt relay in the center console...
Old 06-26-2009, 02:44 PM
The Sharkologist
I don't know if the seatbelt relay would have anthing to do with it... (anyone else have a guess). What about a bad connection behind the gauges? Maybe a harness came loose. Obviously, I'm just throwing ideas out there. Wish I could offer more, Good Luck!
Quick Reply: OB: Pod Gauge and Warning Light Question
