Where to buy full GTS Quarters
#32
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
BB79... so, why is it you need to put GTS quarters on your car? If it is just because of a lot of body filler from a PO... why not just get the quarters you have (early/late) and fix the filler issue? Are both side needing replaced or just one side from an accident? And, if it is an issue of tire clearance -many folks on here have used a baseball bat or the roller tool to flare out the wheel wells for clearance... without the extra expense of GTS flares.
I am not trying to talk you out of creating the car of your dreams -just asking about the motivation behind it...
For large tires, I used a baseball bat on my '88 and fit 295/30/18s on 18x11 wheels (I could go a little larger with 305s)... check it out:
