Cruise Control Question - Fixed
Many years ago the cruise worked perfectly. The first indication of malfunction was its inability to hold speed. Then finally nothing. I performed all of the diagnostics in the WSM. All passed. I also soldiered the circuit board in the control unit. I can hear a click from the Control Unit when I try to engage or disengage the cruise. With the ignition switch on (motor not running), bridging terminals 3 & 5 and 7 & 12 (of the connector that plugs into the control unit) engages the actuating cable. With the engine running should that same bridging sequence cause the actuating cable to move as well? Resulting the engine to speed up? Thanks
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Do all 928's have cruise? My cruise is also not working. I ordered a used 3 way from 928 int and it looks different than my 3 way. Any ideas?
Not sure if all 928s have cruise. The 3-way cruise control lever on mine is just under the wiper control. Not sure about the 81's. I tested the vacuum and it's very strong. I'm going to try another control unit. There's a guy selling them on eBay for 150.00, guaranteed to work. We'll see what happens.
Put the eBay control unit in today. That fixed the problem! Also, I disconnected the vacuum line that goes through the firewall. There's a leak under the console that will be addressed when the dash comes out. The speed hardly varies now due to much more consistent vacuum.
