93 GTS Dyno numbers
#61
Archive Gatekeeper
I find it interesting that the TSB refers to 944 S2 and turbo rods also. I know they have far less issues than the 928 rods do and the S2 has no known issues but that is probably because they are at their power limits from teh factory.
#62
Administrator - "Tyson"
944's are notorious for spinning the #2 rod bearing. My 944S was never tracked and always good oil every 3,000 miles. One day in traffic it started knocking, destroyed the engine.
#64
I will try to remember. i don't have it on this PC and i am heading down the Jersey Shore in the AM. I will leave my self a note for next week.
#65
#66
https://rennlist.com/forums/944-turb...ing-issue.html
It's rare for a street 944 of any model to throw a rod bearing.
I'm curious to know what they did with the S2 to "fix" the problem.
#67
At minumum, the R1 rods would be replaced with better the better R2 rods. Custom rods would be preferred for peace of mind, depending of what is available.
I have been told that the stock pistons are very good and only need to be drilled for oil return in the ring set.
#68
Turbo's have the same oiling issue as the 8V non turbo and the S:
#69
Archive Gatekeeper
I've got five that I'll sell cheap....
#70
#71
what happened to the other 2? I know what happened to piston #8
Greg B sent me an early piston and R1 rod i was going to give you to complete your set so youve got 8 again. I couldnt think of a better purpose for the think honestly.
#72
Archive Gatekeeper
There are chunks missing out of #2 and #6, (6 is much worse than 2, 2 just got pushed up into the valves while 6 kept getting pulled into the melee) and somehow #5 got some shrapnel wounds as well.
EDIT: Piston snuff film:
2,5, and 6:
![](https://webfiles.uci.edu/redwards/public/GTS%20pistons%202-5-6%206-18-09.jpg)
2 and edge of 5 closeup:
2,5, and 6:
![](https://webfiles.uci.edu/redwards/public/GTS%20pistons%202-5%20closeup%206-18-09.jpg)
#74
Archive Gatekeeper
They already look like they've served for target practice. I'll give you a few next time the crew is together.
