Overheating and need help
#32
That was one of the big changes to improve the drag coefficient for the S4.
#34
Thanks to one and all for the help - I am convinced this was all caused from a crapped out relay - I think it was randomly turning the fan off and on which only manifested itself when I sat for a long time idling in traffic. I am guessing the trigger for the fail was probably, as was suggested, due to high heat from being in close proximity to the rad and not in any air flow. Re-jigged and placed a new in-line relay to be infront and to the side of the heat. All "seems" to be OK after a number of short trips to test it out. New relay - $12. Feeling like I am not about to overheat again and blow the engine - priceless! Any merit in breaking open the old relay to see if and how it failed? What would I look for?
#35
928 Collector
Team Owner
open the relay and smell it .
Does it smell burned??
Are there any solder joints that look freshly soldered? ( indicated hi heat to reflow the solder). clean off the contacts in the relay see if it works
#37
Rennlist Site Sponsor
The overheating that you had is almost always airflow related. I never saw an answer on the belly pan and air sealing around the radiator.
That being said, you also need to reconsider the high antifreeze percentage. There is a considerable difference in cooling capacity of ethylene glycol and water. Even in your area, I wouldn't go much past 60/40.
#38
I agree with Wally on the mix. Both cooling and freezing propeties improve with a mix rather than 100% of either.
Drop in some water wetter while you're at it.
