Broken exhaust studs
From: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
I was wondering if anyone has drilled out broke off exhaust studs with the engine in the car? I have IIRC 2 broke studs on the passenger side which creates a horrible exhaust leak that will drive me crazy if I don't deal with it soon. Any thoughts or ideas on this?
Hi Jason,
Yes this can be done - did it myself last month. If it is only the rear most stud you will be ok - any of the others will be difficult to get to though. You need to remove the complete exhaust system and the heat shields.
Space is very tight and the only tool I found that would fit was a small air powered right angled die grinder. I had to shorten a drill bit to fit the space also.
Make sure you have good eye protection as you will get covered in metal chips if you have to do the job on your back under the car as I did!! Took me about two days to complete the job and not one I would want to do again.
I did this. Needed a right-angle drill adapter and cut-down drill bits. Then I broke off the easy-out and that's when the fun really started.
I suggest rolling this into other projects that require pulling the engine. Otherwise get some left-hand drill bits and maybe you'll get lucky.
They should be banned by the UN...
Good luck.
I would suggest the welding option as a first choice however.
Yep it is the standard rear passengerside studs that are broke. I think two of them. As far as easyouts they should be banned. I used one and it broke during my spring and shock job. It delay my job by a month or more trying to figure how to get it out. Ended up using several tungsten carbide drill bits to do it. Then I had to oversize the hole and install a threaded insert. I WILL NEVER USE AN EASY OUT EVER AGAIN ON LARGE BOLTS
