Ok got the gauges and the pressures all look good in spec.
After further research I determined the PO had enriched the mixture screw at the fuel distributor.
It took two full turns to get it running as it should
I did fix a lot of air leaks so that was the only way it would run with the false air.
Now its purring like a kitten thanks for all the assistance
