90 GT aftermarket wheel fitment
I've read numerous posts on offsets but I am not one to take the chance in purchasing a set of wheels to find out it does not fit my car. So here it goes..
I have found two different sets:
Front Wheel Size: 18x8, offset is 52mm
Rear Wheel Size: 18x10, offset is 65mm
and
Front Wheel Size: 19x8, offset is 57mm
Rear Wheel Size: 19x11, offset is 67mm
Will either or both of the sets fit without fender or any other modifications?
Thanks all
and
Thanks all
J I would go with the 18's if the ride matters- I have a 1991 that went from 16's to 18's and I am very happy- and if i had to do another nch- I would go down to 17 rather than up to 19"
Also remember these cars are HEAVY and they love the tires sidewall - Skinnier isn't better on these cars
Where are you in pa I am in lancaster-we should hang-
Joe Cat
Joe Cat
Joe Cat
Joe Cat
J ,
Not really just moved here from long island
. Are you selling your car by chance as there is someone in your town selling the exacy same car on ebay.
If you ever get closer to lancaster- give me a buzz - this is my cell 516-782-2898
I have a two year old- so really there is NO CHANCE i have the time to come there-- But two years and one month ago i would have ..ah maybe i should not put it in print.
Joe CAt
Joe CAt
J ,
Joe CAt
Joe CAt
J, as you can see by my avatar, the 19's fit a '90GT just fine. The fronts are identical, but the rears on my car are 9.5" wide, but with a 46et offset. The 11" wide with the 67et offset should fit fine, especially with the factory roll on the GT rear fender.
I love the look of that 19" wheel. Mine are actually factory take-offs from a Cayman. I would get the real Porsche wheels if you can.
Rick,
The carrera classics look great on your GT. The ones I found are OEM BBS, I didn't want to go with the extra weight of the replicas. Not to mention BBS reputation in quality. Thanks for the input
tire/wheel combo
I am in the same situation. Just ordered hollow spoke Turbo Twist 18x8 with 50 offset and 18x10 with 65 offset. Can someone recommend tire size that will not rub for a 90 GT (soon to be supercharged).
Thank you
Thank you
Dan
'91 928GT S/C 475hp/460lb.ft
The 19" have the better offset but a little marginal on the front. I feel the problem with the 19" will be harsh ride since suitable low profile tyres will have very stiff sidewalls. The 18" are a nicer looking wheel however the front offset is below the recommended offset of min= 55mm - 57mm.
Cheers
Cheers
Your final choice?
What wheels did you end up with and what tires and size did you mount? I just bought some Hollow Turbo Twists 18x7.5 50 offset and 18x10 65 offset and i am mulling over tire choices- I have a 90GT and I do not know if it came with OEM spacers.
Thank you
Thank you
Attachment 361965
and
Attachment 361966
Thanks all
Attachment 361965
and
Attachment 361966
Thanks all
