928 Forum 1978-1995
Sponsored by: 928 Specialists
Jumping A/C compressor ??
Old Jun 1, 2009 | 04:26 PM
Dean_Fuller's Avatar
Dean_Fuller
Originally Posted by dprantl
- Start the car
- While it is idling, turn on the blower inside to position '1' and feel the air temp
- Go under the hood and jumper the A/C clutch wire for 10 seconds. Don't do it any longer than this
- Disconnect the jumper, then quickly jump into the car and feel the air temp
If it is cold, then your freon level is fine and you need to track down the electrical problem.
Dan
'91 928GT S/C 475hp/460lb.ft
Just did this...no cold air. Is it safe to assume the freon has leaked out?
Old Jun 1, 2009 | 04:33 PM
dprantl's Avatar
dprantl
Yup, not enough freon in there. Is this a R134A converted system? I'm not sure I will have enough space in the car for my A/C gear but if there is some at SITM I can definitely assist. But it will not be as simple as just vacuuming the system. You will need to find the leak. Any idea when the o-rings were replaced? Or the compressor shaft seal?
Dan
Old Jun 1, 2009 | 05:12 PM
Dean_Fuller
I have a new seal kit from months ago but did not use it because the system was holding pressure fine over night. No idea where the leak may be. I'm still running R12.
Old Jun 1, 2009 | 05:19 PM
Giovanni's Avatar
Giovanni
Ooppps, sounds like its best to let a shop handle this...
Old Jun 1, 2009 | 05:48 PM
dprantl's Avatar
dprantl
Technically, there is no difference whether you are using R12 or R134A. All you need is the correct gauge manifold and the right freon. Charging is no different. With R12 you just have more $$$ to lose when you have a leak.
Dan
Old Jun 1, 2009 | 06:55 PM
Giovanni's Avatar
Giovanni
But you need to be licensed to purchase and handle R12. Its a little easier to get help with R134A then it is with R12 IMO.
