Aero Kroil
#32
Perfect timing... I need to place an order.
Brought a couple cans of it to the Farm working on #6... the last time I went up there, I found my Dad had used all of it on his tractor and gas pump restorations. He said that it's good stuff!
#33
Just talked to the lady that handles orders since I forgot to put my expire date on the order form. She says thanks for the rush of orders today.
#34
It's what we used 15 years ago to break seized bolts out of large centrifugal chillers...I got about 5-6 cans of the stuff in my cabinet...
As far as the ATF and acetone go....can you pre mix and leave in a spray bottle or is it best to mix before use? What grade of ATF?
Thx...
Thx...
#36
I hope it goes through at the special price. The "MSN - Deal" was already in the "Offer Code" box so I didn't do anything "extra". Is that correct?
There is also a "Google" deal but that one says $5.95 S&H where as this one implies shipping to be included.
#40
Chronic Tool Dropper
Which ATF? Whichever bottle I have handy. Last time I swapped ATF in the Porsche, I captured some of the used stuff for the pump oiler. It doesn't know new from used.
#42
Just pulled the trigger on this, thanks Sean. I used to use Kroil on the IBM correcting selectrics when I was Customer Engineer. It's also great for freeing up gummed up or frozen electric motor bearings.
#43
Got the Kroil flyer in the mail today and while they don't have the 2 fer 1 going on with the Aero Kroil they are doing it with a new product that I am going to try.
Silikroil in the 16.5oz aerosol. Two for $18.50. It's not on the website but if you order it online, put in the comments section that you are wanting the 2 for 1 offer on it and she will process the order for you. I talked to the lady on the phone a few minutes ago and that will be the easiest way to do so.
http://www.kanolabs.com/penLub.html#anchor174712
