View Poll Results: Which exterior mod
I would leave the extrerior unmodified even if it means less effective intercooling
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
1
4.17%
I like wider smile as in the doctored picture, modify the stock part
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
16
66.67%
I'd go with the Strosek piece
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
4
16.67%
Something else, see my post below
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
3
12.50%
Voters: 24. You may not vote on this poll
Would this exterior mod be tasteful?
You got a black-on-black '87 s4 5-speed in Boston? I better go an check the garage! ;-)
Carl
I just realized by searching photos that 968 had that were wider in relation to the car, ending almost exactly at the same spot as in my doctored photo:
![](http://www.studiodual.com/968/CK379-02.jpg)
Coupe:
Cabrio:
http://www.studiodual.com/968/968roa~1.jpg
This is 968 club sport?
http://www.studiodual.com/968/porsche_968_big.jpg
Coupe:
Cabrio:
You beat me to it. My wife's 968 has very wide slats in the front and now that I compare it to the 928, the 928 looks weird with such narrow ones.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
(1) Alan was right. I looked at the bumper cover and spoiler this afternoon. Boy, this would be a project. Implementation at minimum challenging.
Only two out of the three air vents, namely the top two in the bumper cover, could perhaps be modified. Even then, I can already see a number of problems, including the shape of the wheel shrouding profile of the spoiler and the problem of modifying a plastic part made from unknown type of plastic. Because it's a flexible plastic part that takes abuse, I can't even paper in green over the problems because I don't know a body shop that could be trusted to make the mods.
The method that ketchmi and JK are using may be the practical alternative. Especially if the non-hideous Strosek piece is NLA and they only make the hideous one now.
(2) The wheelwell has significant vacuum. I took a ride on the freshly paved route 2 with silicon hose run to both the existing bumper cover vents and inside the wheelwell front of the tire. Watching the radar detector, the road, the traffic, and my home made water manometer proved challenging, but the water column clearly moved. The pressure at the front bumper vent is high enough that one can feel it and the vacuum inside the wheelwell is also high enough that I could feel it. So venting the intercooler flow path from the front bumper, a la ketchmi and JK, is a great idea from the flow perspective.
Tuomo
Man your good at photoshop....(or better than me anyway)......
I think a big consideration is your planned usage of the 928....if you plan for primarily street with the occasional dyno-autox or you won't need lots of extra airflow.....but if you plan to take your big HP TT to the track for hard running in 100+F temps...then its a good idea.....I know some 928 racers cut holes in the middle of the bumper for better airflow.....
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Tuomo... unless you are really good at plastic work, it will be very difficult to have the appearance of the finished ends of the grill slats. Take a look at this bumper cover/spoiler combo from A.I.R. -it is part of their 928 Testarossa kit. The grill slats are already done and as wide as your photoshop pic!
DO you have link to where they sell those A.I.R. bumpers?
Tuomo,
It is: http://www.americaninternationalraci...259246&page=90
That bumper looks like it easily replaces the stock bumper cover.
**No affiliation -just trying to help**
Found this on eBay (no affiliation).........something to consider relative to your topic.
http://cgi.ebay.com/ebaymotors/AMERI...3A1|240%3A1318
Thanks White Lightnin' & Nicholbry.
That ebay piece is for earlier cars, doesn't fit S4 I think.
