Replacement for broken Bosch connectors?
After an exhaustive (for me) search online for a source for pigtails to replace the disintegrated factory connectors on my hall sensor, knock sensor, crank sensor, etc., I have given up .
It seems as if A) they are not available, B) I am not searching for them properly (Bosch connector ?), or C) I must replace both the female and male ends with a new (current) connector. Does anyone have a source for the original ones (less work than replacing both ends) or have some advice to pass on from having faced this problem already ?
As far as I know, Roger has a replacement connector (male and female) for the 3 pole male/female junior power timer connector (that's what it's called) but doesn't have a direct replacement for the male end by itself. My first choice would be to replace the needed end only. I found a site (in Finland) which advertises they have the needed end, and I'm waiting for someone to get back to me. If I find them, I'll post a link.
I have both 2 way and 3 way male & female in stock.
2 way are $12 each and 3 way $19 each.
I also have the MAF connectors in stock as well.
