1982 Fender Removal
I got the fender off and thought I would take a break and post the progress here. I bought this car with a dented fender and have been taking care of all the maintenance. It is a good runner and now she will look as good as she runs.
Other then a good cleaning is there other stuff I should be or could be doing while I have the fender off. Doesn't seem like I opened a huge door to do stuff here but thought I would ask. Thanks.
Also I don't plan to replace to bumper cover will it naturally conform back to the new fender or is there something else I need to do to help it line back up. It's a good hot day here and I have a heat gun if any of that plays to my advantage.
Electron Wrangler
Well your HVAC external temp sensor should be mounted in the alternator shroud air supply hose which is missing... looks like you may have the sensor dangling there (can't tell for sure) you'll need the hose, the "UU" shaped bracket that holds it to the splash shield and the sensor & wiring.
Alan
Alan
Oh and don't miss the little 8mm bolts hidden inside the lip that holds the S spoiler on. Good Luck to ya
I think it is pretty straight forward 8mm and 10mm bolts. The 8mm bolts in the front by the headlight are the worse in my opinion. Have a real long extension for the bolts on the fire wall. I think people make it seem worse then it is, so don't be discouraged. I have some more pictures of the process if you would like to see them. It was also about 100 degress in my garage so that seemed to help me stay motivated
Team Owner
with the fender off you can get a scrub brush and some simple green and clean out the inner fenderwell you will be surprised at how clean it will get
So I went to pick up my fender that was supposed to have been done 2 weeks ago and it hadn't been touched
The owner of the shop "recommended by a good friend" died.
So no one is working there anymore, I guess alot can happen in a month. Lucky for me the former manager the guy I droped off the fender to was there picking up his tools and gave me my fender.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Back to finding a new painter.
I did the harness replacement last year and it was totally plug and play for me. I was doing TB/WP, Porkensioner, motor mounts, oil pan gasket, alternator replacement, etc so that made everything more accessible. No apparent reason to remove a fender.
