928 Forum 1978-1995
Sponsored by: 928 Specialists
GT cams in S4 engine ?
Old 05-04-2009, 09:54 PM
mo-pcar
mo-pcar's Avatar
Default GT cams in S4 engine ?
My 928 had an engine replaced years ago and I'm finding out it was not replaced with same MY and type as I was told at purchase. So my question is can GT cams be installed in an S4 engine. I only ask because my GT appears to have a S4 engine (M28/42 81H05548) but certainly performs like a GT (305 rear wh HP - dyno'd). It pulls strong and idles unlike S4's. BTW what is the H in the serial number? That is what year is this engine?
Old 05-04-2009, 10:01 PM
mo-pcar
mo-pcar's Avatar
I see my pic is still my old S3. The car I'm referring to is a 1990 928 GT.
Old 05-05-2009, 01:09 AM
ptuomov
ptuomov's Avatar
Yes, I believe they can. (Someone who's actually done something like that should confirm, though. Me knowledge of the swap at this point amounts to what one can read on the web.)
Here, by the way, are the lobe separation angles of various combos that once could install (assuming modified S3 exhaust cams):
[wring info deleted]
Old 05-05-2009, 03:02 AM
Vilhuer
Vilhuer's Avatar
All S4, GT and GTS cams are direct bolt on to all '87-95 engines. Intakes and exhaust can be mixed together. Even to level were there is different model cam in all four positions if one modified S3 cam is used. I know one S4 engine where one intake cam was changed to GT cam at local Porache dealer while three other were S4 cams. It did run fine for few years until loose bolt caused some valve damage and engine was changed to another S4 engine.
Old 05-05-2009, 10:53 AM
cold_beer839
cold_beer839's Avatar
If it runs good enough (305 rwhp!!) then I would let it alone.
But in the interest of retaining the value of the car, I would find a GT engine, and there is one for sale for $5500 somewhere in the US right now.
Old 05-05-2009, 05:34 PM
UKKid35
UKKid35's Avatar
I wonder what effect the weaker S4 valve springs would have on GT cams. I have the opposite issue, I have heads from a GT, including valve springs, but the original S4 cams.
Old 05-05-2009, 06:23 PM
Vilhuer
Vilhuer's Avatar
S4 and GT valve springs are exact same part. At least those I have seen.
Old 05-05-2009, 10:26 PM
mo-pcar
mo-pcar's Avatar
Thanks for the replies. I will also say it idles close to 800 rpm and really comes alive at 5000 (GT attributes). I'm disappointed that I don't have a true GT engine but happy with the performance. I did not mention the Authority Chip or Cat delete but even with those I don't thing the Dyno results could be so high.
Old 09-23-2020, 03:54 AM
Thom
Thom's Avatar
Sorry for bumping an old thread.
Has someone on here experience with GT cams on an early '87 S4 using the 9.5:1 pistons?
I am curious how detrimental half a point less in CR would affect performance compared with the standard GT set up with 10.0:1 pistons.
Can the difference in performance be somewhat minimised by increasing both the cam and ignition timings?
Old 09-23-2020, 12:23 PM
SwayBar
SwayBar's Avatar
Yes.
Stock 5-speed S4 dyno's at 270-ish rwhp.
Stock 5-speed S4 with GT cams and exhaust dyno's at 320-ish rwhp.
You will not notice the missing 0.5 point of compression.
You can always increase the dynamic compression ratio by closing the intake sooner by advancing the cam timing, but there's no need to do that.
Old 09-23-2020, 12:43 PM
Thom
Thom's Avatar
Perfect, thanks.
If no difference can be felt then this suggests to me that even GT cams are not aggressive enough for 9.5:1 pistons, which is not really a surprise considering they are still negative overlap cams like the S4's.
Old 09-23-2020, 01:31 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Perfect, thanks.
Measured and felt are different things.
I don't think .5CR is going to give you 10HP...to be then felt...what you don't feel is the 3-4 it offers.
Old 09-23-2020, 02:23 PM
Thom
Thom's Avatar
The 3-4?
Old 09-23-2020, 02:32 PM
PorKen
Inventor
PorKen's Avatar
Long ago when I was researching S3 cams - GT cams are S3 with a tighter LSA - I understood that the S3's needed higher compression 10:1 pistons to compensate for their long duration cams which bleed off intake charge pressure.
Old 09-23-2020, 02:37 PM
Speedtoys
Speedtoys's Avatar
The 3-4?
What do you expect a half point rise in CR to offer?
Quick Reply: GT cams in S4 engine ?
