Electric Mirrors need help
So the original seats (including seat/mirror memory computer) have been removed and replaced with sports seats. I've also taken out the three position memory switch out of the door.
The question now is how to get power back to the mirror switch, to re-enable adjustment of the external mirrors? Has anyone on the Forum come across this problem?
Electron Wrangler
Leonard,
No - haven't done it - but you can try this:
At the under seat 14 pin connector T20:
Connect pins as follows:
Pin 1 (ground) connect to Pin 12 - mirror module ground feed
Pin 2 (30 via fuse 22) connect to Pin 14 - Mirror module power feed
Assuming you have a 14 pin connector plugged in for the sports seats - open it up and install these jumpers with soldered wires in the back of the connector (the sports seats will also connect to these pins 1 & 2). Small wires - 16AWG - are fine for these new connections.
Initially to test this out just install jumper wires into the socket.
Alan
Alan
