Ebay 88 S4 auto $35,000?!
The wheels are very cool
, and I like the aftermarket wing. He may have priced this car a little too high
Looks like the perfect replacement car for Ryan
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Chronic Tool Dropper
There's always the chance that there's someone out there who really wants just that car for just that price. I can only remind folks here that you will seldom get more for your car than you ask. Ergo, if you want more you need to ask for more. Don't beat up on the seller. In fact, dod what you can to get the value he asks. Start a trend.
I sent him a question if each of the "FOUR" stickers (or however he referred to them) were worth $5,000 each because he could just take those off for me and his car MIGHT be worth $15k if he got really lucky! What a freaking idiot!
Okay so Sharky is worth $13,600 according to Fleabay...but this guy thinks he will get $35k.... YA RIGHT...time to step away from the crackpipe!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
However if he got $35k....that means sharky is worth MORE.....for some odd reason I don't see that happening....
But all the work was done by the Porsche dealership!!!
That is the only people that can do work right on a 928!!!
Just look what all the Porsche dealership did!!!!
COMPLETELY SERVICED, INCLUDING ALL BELTS CHANGED, PLUGS BY PORSCHE DEALER. THIS CAR HAS BEEN COMPLETELY UPGRADED INSIDE AND OUT.
ENGINE UPGRADES INCLUDE ALL NEW FUSES, ALL NEW BELTS (ALL 5) REWORKED AND UPGRADED VERY COLD AC SYSTEM BY PORSCHE DEALERSHIP, SPORT RADIATOR AND MORE.
I think this guy got the SPORT RADIATOR package also at the PORSCHE DEALERSHIP, because they are the only ones that can do work like this on a 928.
![](http://i57.photobucket.com/albums/g239/ac4vette/steve%20928/stevecamgear.jpg)
Nobody knows you 928 like the PORSCHE DEALERSHIP
what caused that damage ? now Im scared to put my engine back together.
Rest in Peace
They did not get the rotors tight.
Maybe I am being hard on the dealership, but they do not see older cars, I promise I see more 928 in a year than the Porsche dealerships in Atlanta does, and when you have 10 mechanics looking for work orders, well you roll the dice and take your chances.
I guess I am just upset that anybody thinks that having the dealership do the work makes it special.
I can screw one up just as fast as they can.
Bottom line, buy the tools you need, buy the information you need, ask for help here and double check everything.
A **** retentive owner like me or many others here will do a better job than the dealerships will.
Here is a short list of things I have done to my 87, I have been doing mechanical work for 35 years, I have a A&P license and a few other ratings that mean nothing, just like having a dealership means nothing.
I just copied it, so excuse my wording, it was just for me.
But the bottom line, when I am done with it, it will be about ten times the car that one is and if offered for sale MIGHT bring 15,000!
I have a bit more than that in it.
Things done to my 87 928S4
first off, this is the last known 928 S4 with a squirter block
Water pump rebuild with plastic impeller
tensioner idler
timing belt idler and every thing the belt touches
radaitor end caps and clean core
heater control valve
replace both alternator cooling hoses
new fuses and some new relays
Constintines "SuperClamp" front flex plate clamp
new rear flex plate clamp bolt and clocked for rear bolt down at TDC
complied with tsb on rear flex plate
reseal trans
half shaft seals at diff.
torque convertor bearings
motor mounts (ford)
real gasket oil pan gasket
trans temp switch and all other trans external switches and sensors
replaced both door external handles and installed anti theft plates
replaced rear hatch top and bottom motor units
rear wheel bearings
rebuild rear axles, new boots, seals etc.
rebuilt torque tube
foam under torqe tube
zimerman cross cast rotors, front and rear
new brake dampners
mintex pads
rebuild engine
rod bearings
rod nuts
cradle nuts
valve job
new exhaust guides
new springs, o-rings and seats in head anti drain back check valves
all new seal rings on motor
oil pressure sender
new bulbs in instrument cluster
new gear in odometer (still inop??)
new panel dimmer switch
engine compartment fuel lines
radiator hoses with the rest of the coolant hoses soming soon
all the hoses under the intake
flappy diagphram
new knock sensors
new cam sensor
new crank sensor
new lifters on right side
rebuilt heads finished to 50 RA finish -.005 off head
Block trued and finished to 50 RA -.005 off block
Balance rotating assyembly
944 turbo rings 100 MM
All rod bearings set to .002 except 2/6 which was set at .0025
rebuild cam chain tensioners with new pads top and bottom
new cam chains
Cometic head gaskets ".045 thickness"
GTS rear quarters
GTS mirrors with new motor and glass
New plastic for quater windows
dis assemble moon roof clean, lube and replace guides and drain strip
rub strip delete
metal front undertray
new front spoiler
Carls spoiler protection plates
side marker delete
show quality 2 stage paint this includes compleate tear down of the car and hand color sanded and buffed, no orange
peel anywhere.
new hatch shocks
new hood shocks
new door handle assemblys
Almost every rubber part on the car's outside was replaced
MB Quarts speakers front and rear
500 watt five channel amp
2, 12 inch subs in a enclosure
plug wires (nulogy)
plugs
caps and rotors
Every bearing,seal, seal ring, sensor on engine was replaced.
New main bearings
Rod bearings.
rods checked and refinsihed where needed
Throttle shaft bearing (double seals)
flappy bearings (double seals)
Intake, side covers, cam covers powder coated in Silver Vein
Water bridge and thermastat housing powder coated in gloss black
oil pressure sender
silicone oil pan gasket
new lifters on passenger side
updated plugs for cam journals
every piece of rubber and plastic on motor
Porkensioner
Porsche timing belt
most parts were cleaned with ultrasonic cleaner and all would pass a white glove test, **** was clean.
Undercarriage was cleaned with steam first, high pressure hot water second, and brake clean third, that part is
pretty clean also....................................
Two men spent two days cleaning underside of car.
There has been a lot more done to this car, this is just what has been done off the top of my mind.
I plan to put one of DR's Twin Screw's on this car, and when I am done I will have about a 30 cent on the dollar
car
okay so this was a tightening issue. looks like the key broke.
is there any thing that needs to be changed in that area when taking the cam gear off ? like the key or that steel tripod looking part.
Im planning to get new bolts when Im ready to put mine back.
Thanks for the reply
Rest in Peace
They did not get the rotor tight and this car ended up junk.
I am just venting today, pay me no mind, it just pisses me off when people like the guy selling this car puts so much faith in a dealership doing the work.
Now there are some guys that post here that if they said "Look, this car is perfect" it might be worth that much.
But my guess is that the couple of three folks I am thinking of can find faults in even the most cared for cars.
And that in a nut shell is why a PPI from some one who "KNOWS" is so very important when buying a 928.
That's it, the wifes is going up for $21,928.
Damn............
Damn............
Former Vendor
Ahhh come on guys!Don't be so harsh.We all know that the true value of any car is what someone is willing to pay for it,and like the old saying goes,"there's an *** for every seat".![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
