Small devek rad leak
I have a small pin size hole in my devek rad,passenger side bottom,it leaks about the size of a quarter.The rad fluid was recently changed and it seems that previous owner put rad sealer in the mixture,now that theirs no more sealer in there,shes leaking again.Can i just put a small tack weld rite over were the drip is?
I have used this before and it works http://www.harborfreight.com/cpi/cta...emnumber=44810. I will try it on my Devek radiator as soon as it starts leaking . And probably I will try JB Weld and see if it will hold up before using the aluminum rod.
That is a good question and now that the belly pans are back on i cant view it. The pans are nice to have but i think i have to leave them off,i allways find myself having to get back under there lol
Careful sidehatch, stop leaked killed a friend's shark's engine - caused a head gasket blowout. Ended up with a new engine. Much cheaper in the long run (and short run for that matter) to fix/replace the rad.
Chances are that the radiator is leaking from inside. Deveks early radiators used two different metals between the end tanks and the core. They were all welded together so rebuilding is pretty much out of the question unless you send it straight to C&R here in Texas. Eventually I will be doing that with mine.
Cheaper and quicker fix is just to find a used Porsche one.
