offset of Wheels on ebay?
There are some wheels on ebay item #220394927192 guy has measured some hub to rim measurements, anyone any idea of the off set from these measurements?
you need to know the rim lip to lip width as well to be sure of the offset. most rims are 1 inch wider lip to lip than the nominal width (ie 8 inch rim measures 9 inches lip to lip.) assuming that is the case here, the offsets would be about 50 for all 4 wheels.
