Oil path assistance.
I am wondering if anyone knows what part of the manual I should look at for the oil circulation system.
Mainly the cooler system.
I am wishing to disable the the lines which are thermostaticaly opened and closed which run to the cooler in the rad.
I am wanting to confirm that I can simply block them off/seal them will not prevent oil from circulating through the rest of the engine.
This is on a 1986.5 engine block if that makes a difference.
TIA
TIA
That is how my S4 engine transplant was...when I had the old 82 radiator in there. Had good oil pressure and it behaved as normal. Later, I added the 928 Intl rad with end tank cooler, added the oil cooler lines in place of the plugs, and also had to add the internals to the oil thermostat (spring/plunger). My block is a 91 with only one oil bypass spring too.
Thanks Tom,
I will look in there.
So are you saying that when they plugged off the ports they removed the piston and spring assembly from behind them above the oil pressure sending unit?
Hmm,
I need to add the oil cooler lines to my replacement engine.... I was hoping just to bolt them on, but it now looks like I need to add the spring/plunger too?
For some strange reason, my old engine and replacement engine are both the same year, and were delivered to the same country, but one has the oil cooler as standard and one didn't.
What exactly do I need to retrofit?
There was nothing behind the oil cooler line ports (just a screwed in plug at the block).
Hmm,
Colin the thermostat when it closes directs all the oil to flow through the cooler simply remove the thermostat and you can block the fittings for the lines at the block. The secondary bypass spring plunger allows oil to flow if there is more than a 10-15 lbs pressure increase in the lines to the cooler this was eliminate when aircooled external heat exchangers were added.
You'll need the two parts that screw into the block (that allows the connection of the oil lines), and then drop the oil pressure sending unit assembly. Get a new crush ring for the aluminum part that holds the oil thermostat. If your old engine had the oil cooler lines..just grab all the parts from that one and swap over.
Its just that I remember there being other springs and pistons from the two ports with brass plugs above the oil cooler conections, and didn't know if I needed to install these too.
I don't have the old engine anymore, but I did take every part from it. So basically I need to swap the plugs for the hose connections, and install the spring and piston behind the pressure sensor?
No worries Ben, I got the info I needed.
I also got my new rod bearings in, as well as my I-J crankscraper.
Then I cleaned/prepped my drysump pan for install tomorrow, by then it was too cold to have the garage door open which I need to have for working on the pan area. So I went onto wiring up the car.
Got the center console almost completed.
