Brake Caliper rebuild
My right rear caliper is leaking quite a bit. It doesn't look like a brake line at this point, altho I did get a set of stainless from Roger for all the way around, and will put them on. I looked at the other vendor websites, and don't see rebuild kits for the big brakes - it's an 86.5 MY with the big 4 piston S4 brakes.
What would be leaking if not the hoses, and are there repair kits available? If not, who has a used/rebuilt for sale?
TIA
TIA
Basic Sponsor
Rebuild kist for each caliper piston or circa $40 to 60.
Makle sure where the leak is first.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
The system has the line with compression ring to the caliper. The caliper has pistons with sealing o-rings and bleeder screws.
Use a good brake cleaner to clean the area and with the wheel off and a 'friend' pumping the brakes look if the leak is external or internal of the caliper.
pumping of the brakes doesn't move anything in the caliper (see my other post). I had my wife pump the brakes with the car running, but no pad movement at all. Not sure what's going on with this.
