Airbag Steering Wheel nut size ???
Team Owner
IIRC its a 27mm
Yup, get a short 27 and a longer extension.
lets see how many replies we can get with the same answer LOL
27mm Paul, and yeah a short extension is necessary. The Torx bits are T25 or T15, i forget.
Former Vendor
All the tools are loaded, with the new wheel and shifter.
Now if only the weather can clear up a bit, James will get a new wheel in one of his GTS![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
By the way, I knew that 27mm was the size for the older wheels, I have taken mine in and out often enough, but since the splines are quite a bit smaller on the airbag wheels, I just assumed the nut was different.
Thanks again guys
Paul
Thanks again guys
Paul
Team Owner
disconnect the battery B4 removing the airbag
