928 Forum 1978-1995
Sponsored by: 928 Specialists
!@#$%^ing fuel pump banjo fitting!
Old 03-23-2009 | 02:33 PM
  #31
robot808's Avatar
robot808
Originally Posted by Bill Ball
To counterhold I ground an open end wrench to fit between the posts. Kind of a b%$*^c.
Bill, How did you grind down the wrench?
Old 03-23-2009 | 05:01 PM
  #32
Dennis Wilson's Avatar
Dennis Wilson
Are you sure it isn't leaking where the threaded nipple enters the banjo fitting? This was Dan Perez's problem on this thread. https://rennlist.com/forums/928-foru...ng-out-13.html . Check the last post.
Dennis
Old 03-23-2009 | 08:00 PM
  #33
Charley B's Avatar
Charley B
Originally Posted by Wild Bill
Somebody talk me down off the ledge ........................................................................ ........................................ All I can think to do is order a new cap nut and banjo line... No way to counter hold to tighten the damn thing!
I've had real good luck using a medium sized pair of channel locks when the valve has to be grabbed between the terminals. You can get a good hold by going around one terminal and getting a good set.
Quick Reply: !@#$%^ing fuel pump banjo fitting!
