RDK Sensor Retrofit?
Received 1,622 Likes
Ideally, all that is required is to remove the jumper wire. Plug in the ECU and install wheels with the RDK sensors. If the RDK ECU's been removed then you'd need to find one.
If other means, perhaps involving wire cutters, were used to "bypass" the RDK then it may not be so simple.
