9.5 Inch Front Wheel
I have a wheel problem and need to know the correct Offset and back spacing for a 9.5 inch wheel.
I take from searching several posts that the backspacing should be 8 inches.
What should the offset be for that width wheel.
Thanks,
Ken
Thanks,
Ken
Ken
9.5 wide with 8" back should work fine.....my fronts are 10" with 9" backspacing....with minimal fender rolling I run 295/30-18 front tires and I can even do U turns no problem...but I do have double steering rack stops
Hey guys,
I'm running a 275 on the front 9.5. The problem is that I had a new set of wheels made and when I went to fit them they stick out about an inch. Luckily I didn't provide any of the specs.
I just want to make sure that on the redo, they get it right.
So for a 9.5 inch wheel with an 8 inch back space, what would be the offset.
Ken
Ken
FWIW, the factory Cup Racer wheel (basically a wider Cup 1) is 9.5x17 ET68.
Administrator - "Tyson"
The higher the better, you can always space them out
Wouldn't it be nice if every Porsche wheel was produced with an et70 offset? Just use the necessary spacer, every wheel would fit every 5-lug Porsche (well, almost).
If you had long enough bolts when you add spacers, or use bolt on spacers with their own lugs.
Rennlist Sponsor
Anything higher and you can get into physical interferance on the back side with various "stuff" without adding additional steering rack stops.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
http://www.autolounge.net/calculators/tirespacing.html
Ken
An 9.5" rim with 8" backspacing has an offset of 69.8mm vs my 10" rims with 9" back have an offset of 88.9mm
Another calculator I like to use to determine rim position vs stock is this
http://www.1010tires.com/WheelOffsetCalculator.asp
Using a stock 7" rim with 65mm offset then entering my 10" rim with 88.9mm offset you end up with an inner position 61mm LESS than stock (closer to inside) and only 15mm MORE towards the outside (towards fender)...just as a comparison my Carrera III's are much better on the inside with only 5mm closer BUT the outside is further out at +21mm...... The CIII's with 235/40 tires do not rub at all....not even close with a totally stock setup and about 155mm ride height
On the widow with 295/30 fronts and double rack spacers at about 110mm ride height it only rubs a tiny bit at lock over U turns...& even that isn't bad & the turning circle seems about the same as sharky?
Ken
My fronts are 9.5x18 et 68 with a 265/35/18 tire on a stock S4 with no rolled fenders. I talked to Kim Crumb before having them made, and no rubbing at all.
