Project Perl (maintenance), Part II
Last edited by Jadz928; 06-22-2010 at 01:35 PM. Reason: Deleted for thread consolidation
Vacuum leaks
I am still right in the middle of my winter refresh session with the 88 stocker. I did build that air testing device w/ 3"-2" mission coupler and gauge for the MAF and found a mess o' vacuum leaks..needle bearing rings in flappy throttle valve,vacuum actuator for flappy,blue check valve, etc ..and that was at less than 2 psi, I could hear them. Once the intake was back on , the idle would stumble and quake and stall, put a hose clamp around the rubber flappy cap and it got alot better, so off the intake comes again and now waiting for knock sensor and heater valve..bottom line... vacuum leaks. Thanks for your comments and YES I did enjoy driving the GT 90 and I am happy he was able to sell it
