Vibration help '84 Euro
Wow. This was a LONG time ago.
If my memory is worth anything, I believe the issue was the adjustable fuel regulator I was using on the passenger side rail. I believe it was not holding pressure and fluctuating which was causing a lean condition. The Euros are always a touch lean which was why I was using the 85-86 US 32v damper on the drivers side and the adjustable on the passenger side to crank more fuel pressure in it to mask the lean condition.
HTH
HTH
Yes it does, thank you. I have similar symptoms, have suspected a lean misfire. Need to do some more troublshooting. Your reply is a good data point. Thanks for reaching back into your memory banks.
