"best" engine design software?
To the extent I had any point, it was the following. I think it would be cheaper and more effective (=more efficient?) to use some computer software tools to work out some kinks. I am thinking of the following algorithm:
1. Think
2. Simulate
3. Flow
4. Dyno
5. Go to 1 to rethink
It seems that step 2 could make going where no man has gone before a bit easier.
Im not trying to prove any thing here. I just wanted to personaly test the engines capability on the software, how much HP I can get from it ? I was hesitant to ask the forum for help to make the model but since the question came up I though it would be a good time to bring up the subject.
I would suggest you make model for completely stock '87 s4 with manual transmission. You can later complicate it with an automatic. Once the base model is ready and matches the dyno results, then let's go to town modifying the beast!
People hanging out here are either insomniacs or lack social life (or come to think, probably both) so you'll get a lot of help as long as you are very specific with your requests.
Out of curiosity, which Ricardo software components you have? Engdyn, Pisdyn, Wave, etc. Or do you have everything from them?
ptuomov
Almost Deleted
It was just bull**** gibberish, so don't feel like a dinosaur. Or should it be "dynosaur" in this conext?
1. Think
2. Simulate
3. Flow
4. Dyno
1. Think
2. Simulate
3. Flow
4. Dyno
1.) the simulation has been verified mathematically correct with corresponding empirical testing/evaluation
2.) the time it takes one to run and evaluate and sufficiently large enough simulation that reasonable results can be derived is less than pure empirical testing... [dT_sim < dT_real]
I took a look at the Ricardo software namasgt outlined. Looks pretty interesting. I personally don't have any experience with it but I do with other flow/thermo solvers [fluent/cfx/mfix/openfoam/etc].
..my two thoughts
...assuming two things:
2) Applies to all steps, you shouldn't overthink either! ,-)
But you knew all this already. I am just bull****ting about stuff in a public forum.
In any case, since you have experience with simulations, which I don't, I could use a piece of advice. Should I try to design a sheetmetal intake manifold, which software would a) give reasonably accurate predictions, b) could be learned by a dumb-as-rocks business undergraduate like myself, and c) could be purchased without breaking the bank (a very small bank, in fact)?
Best,
ptuomov
There's been lots of posts about simulations using Engine Analyzer Pro, and other 3d fluid dynamics modelling lately - mostly around work on identifying intake parameters like optimal runner length etc.
You can also find the stock S4 intake dimensions in one of the recent threads - I'll see if I can dig it up (different runner lengths etc. plus the opening of the resonance flap).
Edit: Stock Intake thread - check post 25 for more dimensions
