Could this be a bad Torque tube?
I have a 1989S4 with 151k miles. With the snow on the ground I've only used my car two times since I got it in Nov. I do start it once a month and let it run for 30 minutes. The problem is when I put it in gear ( Auto), even with the brake pushed to the floor it seems like to car moves an inch or so. ( Its not) This "flex" also comes with a light bang like a car with a bad univision joint. This happens when going from "park to any gear or "R" to "D" . Does this sound like a bad Torque tube?
Team Owner
you could have a loose CV joint, check both ends and also the rear axle nut.
The motor mounts could be collapsed or the trans mounts might need to be replaced.
You might be better off not running your car unless you can drive it,... to leave it running for 30 mins will definitely heat up the underbody where the cats are, and could possibly cause a fire, also it can superheat the TT that will over time damage the TT bearings
Basic Sponsor
I know a man who can supply motor mounts 8>)
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
