Long-Term Impressions: Constantine's Upgraded Torque Tube Bearing System
Dave ..........good write up as usual; great use of KY, condoms and shafts...........should make a movie.
Which MY's used the 28mm shaft?
Edit: Ryan beat me to it.
if this is true then i am sorry but i have to question the idea that these shafts are BAD
I heard of a shaft breaking before, but its not anywhere near the issue that say TBF is or anything like that. I think i honestly heard of 1 shaft shearing. I cant say that those numbers would lead me to believe that they MUST be upgraded.
Or maybe the shaft shearing is under reported? But if all 86 and later cars manual and auto have this driveshaft then i think the problem is being over stated.
No im not looking for another $50-$100 solution, i already know of that solution and there are threads here on how to do it.
Please dont take this the wrong way, i am simply looking for an idea on price. I dont hold anyone to it as its totally speculative. But Constantine produced that fact the TT's were $1500-$1800 and if thats the market he is after then so be it, i will bow out now.
As i said above, if its the $500 rebuilt TT market then i think its the way i would go because i see it as a serious upgrade. If it happens to cost $750, well thats probably too much for me too but i dont know, because i have ZERO idea of what the thing could, or should cost.
If so that's really unfortunate. Maybe Constantine's stronger 25mm shaft will take the sting out of that?
Back on again, having a day job does have it's limitations for being on Rennlist.
David, thank you for answering most of the questions on these!
Ryan, we are very aware that the price point needs to be at or below the rebuilt TTs currently available at $500.00 plus shipping. Hate to really corner ourselves yet since we are waiting for a few more details before finalizing the kit price. Think around $500.00 for a two steel bearing unit, which most 928s will work fine with to include the 5 speeds versions due to the new version's robustness, and about the same price of a rebuilt TT including shipping both ways for a three bearing unit, meaning a bit less than $700.00. Once you understand what you are getting for these prices they will seem like a bargain. These pricing schedules should be viewed as introductory pricing and will probably climb up as all things do. Although pricing will always be a concern of ours, we are not positioning ourselves as the low price leader but as a vendor of quality upgrade parts that, for the price, can't be beat.
As far as the 28mm drive shafts, they came in sometime after 1987. From the research we've done they are problematic enough to not offer rebuild kits for them and then be liable for problems. Due to age even the 25mm drive shafts are starting to show some shear problems. That's why we're investing in developing brand new 25mm drive shafts of stronger material.
Thanks for the interest,
Constantine
Constantine
Constantine
Constantine
Does this price include the driveshaft, or that is something that would be extra? In which case rebuilding a GT or GTS 5 speed torque tube required the 3 bearings ($700 +/-) and a driveshaft? ($ unknown)
i guess i just need to wait as everything is very vague. Its very hard for me to get excited about it with so many unknowns.
Then again i dont need a rebuilt torque tube and it seems they are much less problematic on 5 speed cars (which is really all i would have anyway)
I look forward to more firm answers when you get them
Till then, im out.
Hi Ryan,
From the research we've done and email discussions with the Porsche engineer responsible for the 928 driveline during the change of the 25mm to 28mm, we obtained some facts which I think will be help answer your questions.
The automatic 25mm drive shafts were changed to 28mm sometime after 1987 to control the S4 model's increased torque. What Porsche did not change was the front coupler which needed the 28mm drive shaft to be necked down to 25mm. This neck down, found only in the automatic 28mm drive shafts, is the shear point problem.
HTH,
Constantine
HTH,
Constantine
Hi Ryan,
HTH,
Constantine
HTH,
Constantine
Yes, sorry. All 5 speeds have the same 25mm diameter drive shafts, no need to change them unless there are problems with them, such as stripped splines.
Constantine
Constantine
Hi Tony,
To expand a bit more on what David said:
The inner bearing bushing was designed to have a bit more rubber and with a different profile than the original design for a few reasons.
One was to make it easier to push the drive shaft through the bearings without having to use a hammer, which could damage the bearings, or having to use a fancy contraption which is a pain to make.
Another was to have the new rubber bushing grip onto the drive shaft better. This better grip will not allow the drive shaft to merely spin inside of it as the older versions do. This spinning in the old bearing inserts is evidenced by the ghost rings being left on the drive shafts.
Another reason was to allow a bit of mis-alignment of the drive shaft to be taken up by the increased rubber between the drive shaft and bearing. This relieves a bit of the pressure from the internal bearing surfaces making it last longer.
Sorry to hear about that pesky leak! I had the same thing happen to me after my first TT R&R, aargh!
Kind regards,
Constantine
Kind regards,
Constantine
This pic shows the difference in tube length
