speedometer intermittent
After my recent tranny swap, my speedometer is now intermittent.
Is there anything I could have pluged wrong?
Is the sensor in the tranny?
Yes it's clamped to the rear casing (diff). Check if it is tight against the casing, maybe you need to tighten the 10 mm bolt. Also check the connections in the spare wheel well.
