New EZF LH2² pinouts
Ken are these the most current versions?
Suggestion, a date or version number.
Thanks, very handy references.
There's a couple versions of these out there, but to my eyes, they were difficult to read, or lacked info, so I made these.
Single page, landscape:
(EZF_LH22_32V.pdf)
(EZF_LH22_16V.pdf)
Green = sensor
Brown = ground
Black/Red = +12v
Purple = RPM signal
Notes:
-LH pin 15-
16V, 32V, inhibit decel inj. cutoff, is only implemented on green motherboards.
'86.5 LHs with yellow motherboards do not have this feature (missing components).
SAAB/Volvo with LH2.2 use this input to code for automatics.
-LH pin 19-
32V, LH octane loop, changes the O2 sensor loop rich/lean pattern slightly.
16V, Check Engine Light, indicates if the MAF signal is out of spec., LH in 'limp home' mode.
![](http://members.rennlist.org/porken/EZF_pinout.jpg)
![](http://members.rennlist.org/porken/LH22_32V_pinout.jpg)
![](http://members.rennlist.org/porken/LH22_16V_pinout.jpg)
LH 2.2 LH22 LH2.2 ECU connector connectors terminal terminals pins pin plug S3 S2 85 86 86.5 ignition fuel injection
(EZF_LH22_32V.pdf)
(EZF_LH22_16V.pdf)
Green = sensor
Brown = ground
Black/Red = +12v
Purple = RPM signal
Notes:
-LH pin 15-
-LH pin 19-
Inventor
Ken,
DanglerB seemed to think that one of the pins powers the L/100Km gauge located on the Tachometer of an '84 Euro. Do you have any idea which one(s) to test? Would it pin 24 on the LH2 (16v)?
