Dual Radiator-Fan Upgrade: Which do you like?
As your shroud is shot, why not measure the radiator, and have C&R make the shroud to fit the stock radiator.? You may be able to get it all done for less than you expect using a single 3300 CFM Spal Extreme fan... Just a thought, not knocking any of the 928 vendors...
If you had a C&R Radiator, you could also do something like this, and use the Spal 3300 CFM single fan... C&R built the setup in the pics for me.. (Rad and shroud with flaps).... The complete setup pictured is not cheap, but then again, the same setup works on Nascar motors with 800+ HP.......
