warning light 928 '86 european
8th Gear
hello; i can't find out which bulb is dead (maybe is there any other reason when system is warning??) when i'm turning on lights, in a few seconds system is indicating error and "schluss" with lamp diagram appears; everything with lights is OK; any suggestions??
Rennlist Site Sponsor
If the problem is a warning about the lights, there are a few possibilities...
- The Bulb Check unit operates by comparing current draw of pairs of bulbs. This means that if the bulbs are different types; or if there is corrosion in the socket of one or more; or if the ground connections are bad; or if the power connections are bad, then you can get a bulb warning.
- The Bulb Check Unit checks some that you might not think of, such as the license plate lamps and the side marker lamps.
- The Bulb Check Unit has been known to fail.
8th Gear
Problem appears after license plate bulb has broke; after changing for new one warning is still indicating error, but true is that one of the bulbs is lighter than the other; I'll change second one as well tonight; thanks a lot for reply; greetings from poland
Hallo,
Schlußlicht are the two redlights in the rear then light is on.
Bremslicht is brakelight.
Begrenzungslicht is the first position of the lightswitch
Abblendlicht is low beam
Fernlicht is high beam
Nebelscheinwerfer is foglight
Alles klar?
Grüsse aus Germany
Alles klar?
Grüsse aus Germany
