Clutch Rattle
#46
Once again I'm amazed by the mass of knowledge that is accumulated in this forum.
I had the same issue as the OP after I put the clutch back together in my 90 GT. The clutch fork seemed to have excessive back-to-forward free play and rattled somewhat unless I preloaded it by pressing clutch pedal. I was afraid that I had to tear it down again, but after reading the above post I'm pretty sure that I just have bad slave cylinder - it does not preload the arm correctly.
Instructions are in the workshop manual.. page 30-1
I had a problem with the clutch in my '89 - turns out there was too much preload and it wasn't quite opening the return port in the master. Adjusting preload correctly, then the helper spring, gives the clutch a really nice light action.
#47
Although it looks like I will have to tear it down again anyway - to replace the guide tube.
#48
I think I have a similar issue. I pulled my lower cover today to see the clutch the first time. First notice is grease everywhere. its this OK? Clutch rotating mass seems dry. I have a rattle when I engage the clutch and start the car moving. if I "pump" the pedal ( grab, ungrab, grab) it makes the sound.
I did find here that my ball cup on the fork arm is shot. is the play around the TOB ok?
#49
Team Owner
the busing has failed,
replace it,
make sure to clean out the seating area on the arm use a sharp object to remove the crusty plastic.
Press the new bushing onto the ball then fit the arm socket
replace it,
