928 Forum 1978-1995
Sponsored by: 928 Specialists
Disconnected ground wire
Old Jan 14, 2009 | 02:46 PM
LGL's Avatar
LGL
Default Disconnected ground wire
86 Auto: I have a disconnected ground wire about 14 inches long, heavy black, lugged on both ends, and connected to ground on the passenger side fender. Where does the engine side lug fasten. Thanks in advance.
Old Jan 14, 2009 | 11:49 PM
worf928's Avatar
worf928
Picture?
Old Jan 15, 2009 | 06:01 AM
John Speake's Avatar
John Speake
If bolted near the coil, then the other end should go to the engine block. On the 16v Euro it goes to the head.
Old Jan 15, 2009 | 11:31 AM
LGL's Avatar
LGL
Default Picture
Old Jan 15, 2009 | 01:45 PM
Dean_Fuller's Avatar
Dean_Fuller
Looks like the coil ground...attach to block somewhere as mentioned.
Old Jan 15, 2009 | 04:21 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
that wire is usually connected from the coil securing screw to the engine lifting lug, make sure that there is also a similar wire on the other cylinder head both of the coils should have this ground connection
Old Jan 15, 2009 | 08:33 PM
LGL's Avatar
LGL
Thanks all. The coil was hanging loose too so all will be good when I find the hole in the engine lifting lug.
Old Jan 15, 2009 | 08:56 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Engine lifting lug is the securing point for the right hand coil ground and the left side is secured to the lower allen bolt on the back side of the timing cover. Both of the other sides of the wire are secured with the bolt thats used to secure the coil bracket
