upper A-arm spacing question.
I am just wondering if anyone has Carl's steel upper a-arms, and if you do are you running them with S4 lower a arms?
If yes, have you been able to get it down to 1 deg or even just 1.5 deg of negative camber?
If you have used spacers to space out the upper a-arm from the frame, how thick was required to be able to achieve getting the camber lowered? Or could early lower a-arms be ran to get it closer without any negative effects?
TIA
TIA
