If you are trying to find out if someone rearranged your pins this should help.
Check your wiring schematics, looks like there is a wire going to pin 15, should be green with blue stripe at the LH Wireform Connector. According to the schematics this is also for the AC system like Pin 14 is.
88 Year Model Wiring Schematic, Page 10
I have never verified this for sure, but you can easily check continuity between one or the other of the pins on your AC anti-freeze switch and pin 15 of the LH.
Based on this your harness seems to be correct (no pin on 31 and a pin on 15). Not sure if that is what you are trying to figure out, if not let me know.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor www.928gt.com
BTW, a short quick test could be made between LH Pin 15 and "V" Connector Pin 15 and again at "J" Connector Pin 21.
Of course all of this is based on the Schematics being correct and the LH Pinout Chart not being "complete". However, your harness seems to agree with the schematics.
David, how or where do I find the "V" connector and the "J" connector? I'd like to check this out!
Duh, never mind, you mean the connectors at the bottom of the CE panel right?
Yes, you can always go to my website, clck on "928 Fuse/Relay Charts" , select your year and the lowest part of the first illustration shows their locations.
