Engine coming out - any trick to separating bellhousing from block?
its easier if you remove the 6 or 8 bolts that clamp the clamp to the flexplate make sure to mark its position this will also be easier when you install the engine the clamp then slides back on the driveshaft AFTER you remove the clamp bolt from the clamp
When you refit try to make the drain plug in the torque converter be at the bottom of the trans grate and the engine at TDC, thats the way it came from the factory
928, bell, bellhousing, block, converter, engine, housing, motor, plug, porsche, separate, separating, seperateing, seperating, tdc, torque, tricks
