928 Forum 1978-1995
Sponsored by: 928 Specialists
Gas leak
Old Nov 9, 2008 | 01:39 PM
goodspeed928's Avatar
goodspeed928
Angry Gas leak
Im leaking gas from front center of car.
I do not see anything from top side of motor.
Old Nov 9, 2008 | 01:48 PM
the flyin' scotsman's Avatar
the flyin' scotsman
Can you tell if its from the front or rear of the engine?
How old are the fuel lines, regulator, dampers?
Old Nov 9, 2008 | 03:37 PM
goodspeed928
It must be the lines next to the firewall.
Old Nov 9, 2008 | 04:08 PM
Mike Frye's Avatar
Mike Frye
Craic Head
Greg, I think you're right it's probably the fuel cooler line. Call Roger and get a set of FI lines and don't start it until you get them replaced. The whole thing can be done in 2-3 hours in your garage and all you have to remove is the airbox, intake tubes and MAF.
Good luck!
Old Nov 9, 2008 | 04:23 PM
the flyin' scotsman
Roger has the FI line kit; I'd change them all:
