Left Side Gages InOp
Well I got the beast running but the gages on the left side of the instruments are not working.
I reached under and made sure the flat connector was plugged into the left side but no joy. Any ideas? While I had the Pod out I did a Odo gear R&R.
Add pics for the unimanagitve, if possible.
Team Owner
First check the fuses, then you might have to remove the pod and check the connector it may not be connected correctly, disconnect the battery before you remove the pod
