My Turn.(Limp home mode? - rv)
#76
9203
Subject: Diagnosing Ignition Monitoring System
ATTENTION:
Service Manager/Service Technician
Models Affected: 928 S4/GT/GTS >From 1989 Models ->
Concern:
Checking of components after activation of the ignition monitoring system (injection circuit switched off fault codes 1131 of 1231). Activation may be caused by the following:
- Damaged or defective exhaust gas temperature sensors.
- Possible damage to the ignition coil wire left side (in driving direction) between the ignition coil and distributor cap.
- Poor grounding of the mounting plate for the ignition final stages.
- Poor physical connection of the electrical plugs on the ignition final stages.
Parts Information: New version temperature sensor Part Number 928 606 155 02 New coil wire with hose covering Part Number 928 602 040 01 (for left side)
Repair Information:
1. Check the left side ignition coil wire. Be certain the coil wire is routed freely and not under tension. If damaged, replace with new version (see parts information).
2. Check all ignition components and connectors for corrosion, tightness, correct connection and damage. Repair or replace as necessary. If an ignition circuit has malfunctioned, an LED indication will be given by the ignition monitor relay located on the L-H control unit mounting plate. Ignition circuit I (cyl. 1-7-6-4) Red diode Ignition circuit II (cyl. 3-2-5-8) Green diode
3. Before replacing temperature sensors, check the voltage difference of both temperature sensors as per step 4 of this bulletin. Sensors are located in the exhaust ports: Model '89-'90, cyl. 4 and 8 Model '91 cyl. 3 and 7 The function of the ignition circuits and light diodes located in the ignition monitor relay remains unchanged. It is not possible to determine from the LED display of the ignition monitor relay if one or both temperature sensors are defective or which temperature sensor has failed. When installing temperature sensors, coat the sensor adapter threads with molykote paste HTP (white) and torque sensors to 10 N-m.
4. The voltage difference of the temperature sensors must be checked in order to ensure proper operation of the ignition monitor system.
Checking sensor voltage difference:
- Start engine and bring to operating temperature.
- Loosen the mounting bolt for the ignition monitor relay and pivot the relay up to gain access to the plug terminals Do not disconnect the relay plug.
- Set volt meter to the millivolt range and connect leads between E1 and E2 of ignition monitor relay (Figure 3, white wires). A digital volt meter must be used. Polarity is not important.
- Measure voltage with the engine idling and again at approximately 2000 RPM. A maximum difference of +2.5 mV or -2.5 mV (depending on polarity) is permitted. If the voltage difference is above 2.5 mV, stop the engine, loosen and rotate one temperature sensor. Retighten sensor and check voltage difference. If the difference is above 2.5 mV, stop the engine and rotate the other sensor. If after rotating the sensors to different positions, the voltage difference is too high (above 2.5 mV) the temperature sensors are defective and must be replaced.
ATTENTION:
Concern:
Repair Information:
#77
9203
ATTENTION:
Concern:
Repair Information:
ATTENTION:
Concern:
Repair Information:
#78
And this related item too.
______________________
Broken Central Tube Shaft Vehicles With A/T
9228porsche01
July 7, 1992
Model 928 S4
Group 3
Part Identifier 3903
Number 9206
Subject: Broken Central Tube Shaft Vehicles with Automatic Transmission
ATTENTION: Service Manager/Service Technician
Models Affected: 928 S4 Model Year 1989 to 1991
Concern: Activation of the ignition monitoring system (injection circuit switched off fault codes 1131 or 1231) can lead to breakage of the central tube drive shaft.
General Information: Oscillations in the central tube system that occur when the ignition monitoring system has switched (flywheel effect) can lead to breakage of the central tube drive shaft. This can occur only in vehicles with automatic transmission where the vehicle is operated at an engine speed of approximately 1000 RPM. Possible causes are:
Parts Information: A new version temperature sensor, central tube and coil wire are installed in production.
Temperature senso, Part Number 928 606 155 02
Central tube with changed material for drive shaft, Part Number 960 421 012 07
New coil wire with hose covering (for left side), Part Number 928 602 040 01
Repair Information:
1. If the central tube drive shaft is broken, replace the central tube with the new version part (see parts information). Refer to Technical Bulletin Group 3, Number 9203, dated May 5, 1992 for hints on central tube installation.
2. Replace the left side ignition coil wire with the part number listed in this bulletin. Be certain the coil wire is routed freely and not under tension.
3. Check all ignition components and connectors for corrosion, tightness, correct connection and damage. Repair or replace as necessary. If an ignition circuit has malfunctioned, an LED indication will be given by the ignition monitor relay located on the L-H control unit mounting plate.
4. Replace both temperature sensors located in the exhaust ports:
Use the new version temperature sensors listed in this bulletin.
5. After the temperature sensors are installed, the voltage difference of the sensors must be checked in order to ensure proper operation of the ignition monitor system.
________________________________________
9228porsche01
July 7, 1992
Model 928 S4
Group 3
Number 9206
Repair Information:
#80
Because of time constraints, only got around to changing the plugs today. #5 was the old plug. #8 is cleaner than other three. Seems as if it's barely firing. After replacing everything...no fix. Green LED is on, no flickering this time around. Starting the coil wires tomorrow. Then relay/sensors.
#81
So it's replacement could fail, too.
A more clever approach is to run *tests* that identify your problem. You can spend brainpower or your bank account, though...either should get you going again eventually.
#82
Tru dat. But...I wanted that old plug out anyway. The coils are new, just gonna check the seating and see if anything is strange going on in there. No money spent except for spare MAF. Weekends are made for tinkering, all tests will be done without spending loot.
#84
You so-called experts missed the most obvious: following T-belt replacement I failed to connect DS coil-distributor. This will cause the dreaded green LED 99% (or more) of the time.
#85
Team Owner
Ahh Donald, you missed a page try post #73, This is one of the first things to check
#86
You're just replacing parts, throwing new parts at the problem. That's the costliest approach, and often times you'll get a short-term "fix" from replacing a failed component without curing the long-term problem that made the part fail in the first place.
PS - find those wires from the temp sensors and just monkey them around a bit, too. Unplug their connectors and plug them back in.
#87
Bad distributor cap. While in there, found leaking heater hose, crumbling plastic fittings, corrosion everywhere. So...will replace o2 sensors , temp sensors, along with heater hose and cap.
