Plug Wire Distributor Ends?
In the course of a TB adjustment, somehow I managed to break the distributor ends off my #6 plug wire and my coil wire on the passenger side.
Is there a source for distributor ends that can be attached to the stock plug wires?
Thanks.
Thanks.
Basic Sponsor
Mark,
You need 928 602 557 00 $21 each.
Roger
Roger
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Thanks, Roger. How do they fasten? I figured they would unscrew to reveal a male threaded end on the wire, but I tried to unscrew the distributor end from the #6 wire and out came a ragged end.
Basic Sponsor
Mark,
They should unscrew to reveal a small male thread.
Either the end has come off or they are not factory wires.
There are some good aftermarket sets out there that do not use the screw on ends.
IIRC you can buy the individual wires and I can check for you early tomorrow.
Part number for #6 is 928 602 060 24.
The coil wire is definitly available as I have supplied a number of them.
A complete set of Beru wires is $385 so that is the worst case.
Maybe a used #6 wire from an old set - check tomorrow for you.
Roger
Roger
