Squealing starter motor
I'm sure this is a basic question. When I start my car, for the instant that the starter is still engaged but the engine is firing, I get this high pitched squeal. If I hold the starter a little longer it squeals longer, just to verify the connection.
Is this a symptom of a bad solenoid or starter? Anything else to check? Normal?
Would you just use motor oil, or grease or gear oil?
Motor oil would be good you wont need much, and be careful with the starter drive I would spray some Marvel Mystery oil in it , not much
Our main reason for using grease was the water resistance - if you don't think the starter ever gets wet, check after driving thru a puddle.
Seriously - you can refresh your own starter easily. The problem with a rebuild is that nobody sells parts to the general public anymore.
A rebuild consist of cleaning, disassembling, and
#1 checking the armature on a growler - this lets you know if the windings are good before you waste your time.
#2 Checking the fields - this can be done with a ohm meter check for ground against the case and a visual of the insulation.
#3 Turning the armature commutator smooth in a lathe - (a 1/2 inch drill while applying emery cloth, then using a dental tool to clean between contact flats is darn close), again looking for overheated insulation.
#4 Cleaning the shaft so the drive slides, yada yada ...
#5 Replace brushes, pressing in new bearings and/or pressing and honing bushings, and cleaning or replacing the starter drive.
#6 Assemble with new insulation on post and new nuts.
#7 check both solenoid coils - there is a pull in, and a hold in.
#8 Paint and tag.
Cost to rebuilder is generally less then $20 to $35 and 45 minutes labor - unless the drive is bad (often a good soaking fixes it). Small drives (like a car starter) are $8 to $12 and those on the larger diesels run upwards of $120.
The problem now days is that anyone can get a job in a national rebuild shop and they have no quality control. Yours might have been rebuilt by someone who just started yesterday. A local shop who hands you back your starter or alternator is often the best bet.
You can take yours apart, clean it, and put it back together.
Unless it needs an obvious part, quite often they just need a good cleaning and lubrication - there are naturally little tricks that make each brand easier to put back together - but time and experience are the best teachers.
Pulled my starter, cleaned and soaked the drive unit. No change. Took it to a local electric shop. Tested OK. I asked them to open it and check it anyway. They cleaned and lubed it. Re-installed, no change.
Ordered a rebuilt Bosch unit from DR. Beautiful unit, re-installed still have squealing just before I release the key from from start position after the engine catches. After R & R starter x3, I think I'll just live with it.
BTW while under the car I saw a torn steering rack boot so I changed it. I have to say between putting the sway bar back and getting the rubber boot over its ridges and fittings, I'm pretty sore. I think my car likes to wrestle!
Thanks for all the help and encouragement.
fit the outer seal of the boot and connect the outer tierod and tighten it to it original position. The starter noise has me wondering
I have a remote starter installed on my car, and when it starts my car there is no squealing, even though I can hear the starter engaged momentarily after the engine fires. Could the symptoms I described be an ignition switch malfunction? Is there a starter inhibit circuit which is not working and letting the ignition switch do something bad? I'm hoping Alan might look at this. BTW the ignition switch is about 2 years old but I did notice on a couple of occasions that my key was hot after shutting down the car. Don't know if that means anything.
Thanks for looking and your suggestions.
The difference may therefore be that when starting with the key in starter mode the X Bus is disabled & 15 bus is enabled while via the remote starter the accessory bus is (likely) also enabled.
On the face of it you'd expect any belt squeal to be worse with higher alternator (& potentially compressor w/ AC on) loading. But sometimes you need just the exactly correct loading to cause the worst noises.
I'd still check/tighten the alt & compressor belts and maybe check the compressor clutch operation...
Alan
Alan
Dave
